super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Pip_Jones
Aug 20, 2011Aspirant
Hi, apologies if this has been posted / resolved before - if it has, I can't find the solution!
I'm using:
ReadyNAS Duo with RAIDiator 4.1.7 [1.00a043] with IP 192.168.0.2
Transmission. P2P Client v2.33
NetGear DGN3500 router
DGN3500 Router is configured with:
Service called "Transmission", type "TCP/UDP", ports 60000 - 65535
Firewall outbound rule ALLOW always, Transmission service, Any LAN, Any WAN
Firewall inbound rule ALLOW always, Transmission service, LAN 192.168.0.2, Any WAN
I can access the Transmission web interface without issue.
I can add torrents without issue
The problem is that the torrents will not download, or connect to anything.
From the Web UI, the preferences / network tab is reporting:
- Peer Communication: Enable Micro Transport Protocol (uTP) is Enabled
- Peer listening port: Incoming TCP Port: 61413 "Port is closed"
What am I doing wrong? Please help ...
I'm using:
