super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
n0guest
Aug 21, 2011Aspirant
it's huge memory leak. I've Tested on 2.31, 2.33 with my Duo with 256Mb RAM, RAIDar 4.1.7.
confirmation that this is a memory leak - information in the output of utilities top and logs in /var/log/syslog
if transmission-daemon only started (or verifying files) - all is ok, memory consumption 5-8Mb.
when add torrent, but not start it (not downloading) - same situation with memory usage.
start torrent downloading and memory leaking on 3-5Mb with 10 seconds.
i'm tried to disable utp, dht and change some other settings - no result.
think memory leak is related with the downloading torrents data, but how fix it?
super-poussin, can you help to locate and fix this leak?
I am willing to offer a reward for your help in solving this problem (eg, paypal donate).
moreover, that according to previous reports, this problem affects many users.
ps: if you do not want or for whatever reason can not help to solve this problem,
please, I would like to hear your opinion on the possible solutions to this problem.
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10319 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10320 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10321 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10322 (transmission-da).
