super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
n0guest
Aug 22, 2011Aspirant
In my case (installed original 256Mb memory, not upgraded or replaced) helped only downgrading to version 2.11.
My ReadyNAS Duo running second day without Out-Of-Memory killing.
Transmission up and running normally - used in total 20-30Mb, seems memory leak stopped.
I'm still waiting for a response from the super-poussin, perhaps he will tell what the problem with newer versions of Transmission (> 2.11).
May be his Transmission builds require some newer versions of libevent/libcurl not available on RAIDar 4.1.7 and early versions.
In my past experience is a version mismatch of libraries can lead to crashes, memory leaks and other failures.
But we need confirmation from the super-poussin - what library versions he was used to compile Transmission.
