super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Retired_Member
Sep 06, 2011
Blues wrote: I seem to be the only person who is having a problem with installation... Immediately after clicking on "install" I get a message telling me that it conflicts with another add-on even though there are no add-ons installed (according to the add-ons screen). Could there be some directory or file, that the install routine is trying to create and assumes is not there, that may be causing the problem? Maybe I can manually remove that before attempting to install it again.
I have the same problem. I thought Transmission had been un-installed. In /etc/frontview/addons there is no "TRANSMISSION.remove". Nothing either in /tmp/addons.
I found a bunch of files in \\NVX\addons-config\Recycle Bin\Transmission, but removing them didn't make any difference.
I can't think where else to look
