super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
dsm1212
Oct 05, 2011Apprentice
First thing I'd check is if you've enabled ssh access connect to the system use "ps -ef | grep transmission" to see who the process is running as (should be user nobody). Then go to /c/media/BitTorrent and make sure that user has full access to that directory and all of it's subdirectories. Something tells me I had the same issue after I installed it and fixed it this way.
