super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
mustang2
Oct 08, 2011Aspirant
dafunk85 wrote: I have a problem after installing transmission 2.33.2 in my readynas pro 6
the problem is, after installing transmission, it replace all my data files in media folder especially in CIFS sharing protocols, it replace with transmission folder but the files is not deleted just hid by transmission folder.
the question is, can i make my data files back appear again, coz i really need those files, especially when share with CIFS share protocols, the other protocol is not problem
please , really need the solusion :(
I have the same problem with ReadyNAS Ultra 2. I just installed transmission for the first time and was prompted to update to version 2.40.03 which took several attempts to update. After that my saved files were no longer visible on the ReadyNAS or through Windows. The funny thing is that the ReadyNAS Frontview disk usage indicated that the files were taking up space and my TV was still able to stream these files via DLNA service. I had to reset the unit to factory default and start from scratch. Seams like a bug somewhere.
