super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Chod
Oct 31, 2011Aspirant
Just installed latest Radiator 4.1.8 on a NV+ with latest Transmission 2.42 (released today) and get:
Oct 31 22:38:04 netgear kernel: Free swap = 419008kB
Oct 31 22:38:04 netgear kernel: Total swap = 767904kB
Oct 31 22:38:04 netgear kernel: Free swap: 419008kB
Oct 31 22:38:04 netgear kernel: 14141 pages of RAM
Oct 31 22:38:04 netgear kernel: 216 free pages
Oct 31 22:38:04 netgear kernel: Out of Memory: Kill process 3033 (transmission-da) score 43330 and children.
Oct 31 22:38:04 netgear kernel: Out of memory: Killed process 3033 (transmission-da).
Oct 31 22:38:04 netgear kernel: Out of memory: Killed process 3034 (transmission-da).
Oct 31 22:38:04 netgear kernel: Out of memory: Killed process 3035 (transmission-da).
Oct 31 22:38:04 netgear kernel: Out of memory: Killed process 3036 (transmission-da).
I was running a single torrent which was downloading for about 5 mins and then the crash. I tried restarting and it just happened again.
My NV+ is stock standard, no memory upgrades. Should I be used .42 or should i be using this lite version i hear so much about? I did not modify any settings after the install, everything is right though. The defaults always worked in the past. Should i disable the blacklist? DHT?
Any help appreciated.
Edit* I should mention the only add ons i am running are transmission. The only file sharing protocol is CIFS and everything else works fine. Not sure if any of this makes a difference.
