super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
JarnoG
Nov 08, 2011Guide
The addons-config folder is a share, so the easiest way to get there is by browsing to your NAS using CIFS and the admin account (the one you use to log into Frontview). After that you can look up the settings.json file at the location mentioned. The addons-config folder isn't visible is you log in with CIFS using a guest account (if you give no credentials).
I'm using Transmission to download from private trackers and it's working fine with me. The only "problem" i see is that it doesn't show the total amount of seeds/peers when i'm using private trackers, it has no problem connecting to them though. It does show the total amount of seeds/peers when i'm using a public tracker.
