super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Dec 02, 2011Guide
Of the top of my head i'd say it's a connectivity issue, rather then a issue with the NAS it self. Hardly fun, but just to make sure i'd start with the router. I use uPnP, so i haven't even configured ports. See if you cant set yours to uPnP, and then jump in to transmission, and do it there to.
BTW, you, and your brother are accessing the same tracker? Have you checked with the "staff" to make sure they don't enforce limits of some kind? The tracker might not like the two of you trying to seed and leech torrents at the same time, from different identities, if it thinks your coming from the same place. (same IP) Also if thats the case, then shutting your bro of over night, and then trying yours before his, with a fresh torrent, should get you going, and give him the same error message. Also i know at least one tracker i had to switch from "secure" login to "normal", to let the NAS do the torrents. In my profiles that was mentioned as needed to log in from multiple locations, but on the tracker forum it was also mentioned as needed for seedboxes. Apparently, even as the NAS is on my private net, it needed that setting, on that tracker. None of the other trackers have needed anything similar. But i'm all alone on my subnet, so to speak.
B!
B!
