super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Dec 02, 2011Guide
I THINK uPnP is labeled "use port forwarding from my router" under network in preferences, or you simply use transmission remote dot net, where it's on the general tab of Options/remote settings.
In the router it's Advanced/uPnP and a checkbox for "Turn uPnP on"
If your torrents run of uTorrent while your bro runs them of the NAS then you should be able to get it to run of the NAS to. Check your profile on the tracker, and / or ask the crew for ideas, see if they know what it can be related to. As i said, i had a similar issue where the tracker wouldn't accept my NAS until i switched to a different security setting on the tracker. Cant for the life of me remember the error message.
B!
B!
