super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
castiboy
Dec 13, 2011Aspirant
Mr_B wrote: What thread would that be? I might need it soon.
Cromm wrote: There's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
B!
This would be it:
https://www.readynas.com/forum/viewtopic.php?f=36&t=58589&start=30
Transmission has been pretty unusable on my old duo since I upgraded my drives and did a clean 4.1.7 radiator install. At first it was just horrible DL speeds and the really low number of connected peers, to the point I stopped using it for a while... (with all versions of transmission 2.1 and above, including the one that worked before the upgrade)
It got better a few weeks ago but speeds weren't great, still I decided to give it a shot again, and then it just started crashing on me repeatedly, no matter what version I use (duo runs out of memory, kills transmission).
I'm currently on the latest v2.42 and it's been 2 days since I changed the cache size from 200 MB to 8. Not only has it not crashed on me, I'm actually downloading at 1.3-1.8 MB/s, whereas it wouldn't go above 500 KB/s since the system reset.
