super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Dec 13, 2011Guide
1.3-1.8MB/s is what i see as default, but i got the NV+ and stuck a 1GB memory in it, so i suppose that does it. I'll see if i can log on to the share, and try the settings change, but for some reason it defaults to Readynas/Guest as user, and it cant be changed. (grayed out) I guess it's a issue with Windows XP x64, so i'll try and get a laptop running on the net and see if i can tweak it. Anything i can do to increase speed and stability is a good thing. Thanks for the link.
B!
Edit
My memory was wrong, it wasn't the user name that was the issue, the darn thing just didn't ant to accept the password sent as the right one. The laptop made easy work of it, and i set it to 20, for a starter test... I'm hoping to get slightly better speeds, more then some huge boost in reliability.
/Edit
Edit (Second)
Seams to do what i was hoping for it to do. I'm hitting 1.9MB/s right now, without a doubt the fastest single download since i started, and thats with a few (very slow) streams going up. Not much of an actual speed improvement, but it seams to stay at speed rather then bouncing up and down as it did before.
/Edit
Edit (Third)
Upload-speed "record" is currently 3.2MB/s, but it still bounce pretty much as it did b4. The average download speeds are "a lot" higher, so over all, speed improved quite a bit. If you haven't tweaked the cache size, and you have a good speed connection, do it, regardless of stability issues.
/Edit
B!
Edit
/Edit
Edit (Second)
/Edit
Edit (Third)
/Edit
