super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
JarnoG
Jan 03, 2012Guide
You could try to reduce the amount of resources that Transmission uses by changing these parameters in the settings.json file:
Lower values for these settings mean lower resources needed. You can try out a couple of values to see what is working for you. Higher values gives faster transfer, untill your NAS can't handle them anymore. (the peer-limit values can also be set from the webGUI)
"cache-size-mb": 32,
"peer-limit-global": 50,
"peer-limit-per-torrent": 10,
