super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
roostaar
Jan 16, 2012Aspirant
I had been running Transmission (up to 2.42) on my NV+ for several years without issue.
I recently upgraded the RAM from 256 to 1024 and now have had a failed HDD and issues with Transmission (now that I have restored to factory defaults with a new RAID array).
The HDDs are WD EARS 2TB with 4k sectors so unsupported on 4.1.8 without a factory restore and I knew the drive already had bad sectors so that has been RMAed.
The two remaining drives are running fine under 4.1.8 with 1024 RAM and multiple memory tests report no issues.
My issues with Transmission are that if I try to edit settings.json at all (as I have done many times in the past) Transmission will not restart correctly.
Disabling and enabling in Frontview takes much longer than before and after editing settings.json, 'Transmission service failed to start'.
I have tried rolling back to 2.31, same issues.
Frontview also often shows checkbox checked but no green light, or green light lit and checkbox unchecked. Strange.
Also, transtop.sh works using SSH but transport.sh does not.
Anybody else experiencing this? Should I re-install my firmware again?? If so, what's the best way to do that without losing my data?
Cheers all
Cheers all
