super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
ranthony1
Feb 05, 2012Aspirant
Mr_B wrote: There is only one. There can be only one. Everyone has to understand one and other.
ranthony wrote: Does one provide better encryption over the other?
I was referring to the options, 1 or 2.Yes. Encryption relies on CPU calculations, so encrypted transfers cost CPU time. This should be weighted against the fact that some use encryption, some don't. If you go with 0 or 2 you can only talk to people who have the same setting, or 1. So for maximum availability of peers, 1 should be your choice. Then you can talk to everyone. (0 = Off, 1 = Preferred, 2 = Forced)
ranthony wrote: Is there any performance impact?
I'd like a 4'th option here actually. Encryption enabled, but unencrypted Preferred. But 1 works well enough.
B!
Thanks for this, it helps.
