super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Feb 05, 2012Guide
I was only clarifying, your question sort of indicated that there were alternative encryption methods in use. I'm honestly not up to date on exactly how the encryption works, but to keep snooping eyes out it would seam likely that you follow a set of rules and use a random salt, and simply trade the salt during initiation of the transfer.
ranthony wrote: I was referring to the options, 1 or 2.
Anyway, i guess "better" could mean reliably encrypted, in which case 2 is the only way to go. With any other option your going to have stuff that isn't encrypted.
ranthony wrote: Does one provide better encryption over the other?
No worries, i'm happy the little i know can be useful from time to time. If nothing else it makes me look good, as a good counterweight for the times when i look like a complete fool.
ranthony wrote: Thanks for this, it helps.
B!
