super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
MrAsker
Feb 17, 2012Tutor
endremerk wrote: I'm having the same problem as the guy a bit further up.
Transmission says that "Port is closed" when I check the port in the UI menu.
I've tried a variety of versions, neither of them are working.
I've checked my router, and the port is open. (Even tried to change the port, and I can see that my router automatically changes so that the chosen port is open)
I also tried to use the "in-built" torrent client, but this is not working either.
I recently moved, and as far as I can remember, I was able to use the Transmission Add-On before this.
I've brought the router from my old house, but I've changed the ISP.
I first thought that the ISP in some way was blocking Torrent traffic, until i booted up my Ubuntu machine and tested Transmission from this. Works like a charm.
I'm lost here. Are there any others who have encountered this (and found a solution)?
EDIT:
Oh, and...
Current version:
RAIDiator 4.1.7
Transmission 2.31
As it can be seen in other posts I also have problems getting Transmission 2.42 to work as expected om NV+. Reverting to the built-in BitTorrent client works so I'm pretty sure the problem is Transmission. I'm more then willing to turn on more logging, do debugging, etc if you someone help me with what to do.
