super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
JarnoG
Apr 14, 2012Guide
There hasn't been an update for the sparc nasses because the Duo super-poussin used to test them died. I'm afraid you'll have to wait till he has some replacement for it.
About the ports, you should check if your router is forwarding it to the correct IP. If you are using upnp to get the port forwarding, you should check if upnp is turned on on your router and if your nas is supplying it with the right IP to forward to. If you manually set the port forwarding on your router, make sure the IP of your nas does not change.
About the magnet links, I've noticed that sometimes it takes a really long time before it starts downloading, especially if there aren't a lot of seeds. At one case it took several hours before it started.
