super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Orionos
May 04, 2012Aspirant
Whenever I try to install the Transmission plugin it goes as far as validating the image. When I click install, the 'hourglass' stays on the screen indefinitely. The display on the NAS states 'Installing Addon' for a few seconds.
If I refresh the screen or access it from another browser session, it shows Transmission as installed but not running. If I then reboot the NAS, it gets stuck on 'Installing Addon' and the only option for me seems to be a factory default, since I have no idea how to access that little install routine to disable it (Anyone know how to do that, through Tech Support mode maybe?) and Reinstall OS gets stuck too.
Same thing happens when I click om 'Remove' in the Frontview interface. However, if I run TRANSMISSION.remove manually, there's no issue. And then a reboot goes fine.
Tried it twice now, with Transmission 2.33 and 2.50. No go on either, and I'm getting tired of having to factory default every time. Resync is no fun.
Maybe something to do with x86 4.2.20 firmware? Any logs I can check?
EDIT: Trying to start the service through Frontview hangs as well.
