super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
arehsan
May 04, 2012Aspirant
WhoCares? wrote: Changing the start.sh file is the wrong solution for your problem. Try changing the /etc/init.d/transmission-daemon file instead.
-Stefan
Thanks!
I ended up setting the USER variable in that file to admin:superusers and then I set the umask in settings.json to "2", so Transmission would function normally with the admin as user, and anyone in the superusers group should be able to read and write.
