super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
JarnoG
Jun 14, 2012Guide
@ Prostheta: you can change the settings of Transmission in a file called settings.json. It is located in the folder Transmission/transmission-daemon on a share called "addons-config".
You can find settings that proved to work for a Duo here. He has set rpc authentication on, so I guess it's working there too. You only have to change the password (change the part between "", including the {, to whatever password you want) and start Transmission again.
@ G man: I'm not saying it should not happen with the latest version of Transmission, just that I did not had any problems anymore after the update. That was also somewhere around my update to Radiator 4.2.20, so that might have got something to do with it as well. I've got "rpc-authentication-required" set to true and it's working fine for me.
