super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Dewdman42
Jun 19, 2012Virtuoso
running the TRANSMISSION.remove script manually I was able to remove it fine. I don't know why it does not work from frontview, the addon appears to be broken for that too.
For the start.sh I fixed the bug and got it to work. by changing the UPGRADE_FW variable to a string using "NO" and "YES" instead of number 0 or 1. There was a typo in the name of the variable for the test at line 37 also. This made the script run and it did start Transmission finally, which seemed to work. However, frontview control did still not work. Trying to start it or stop it causes endless cursor spin, as does trying to remove it.
