super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
gibxxi
Jun 24, 2012Guide
If your installing over a previous version, you will need to edit the transtart.sh, transtop.sh and blocklist.sh files in the addons-config/Transmission folder/share. By default, the password for the admin user is set to password1. If you've changed that password for the admin user, the corresponsing entries in the files listed above need to also be edited to match your new password. This ought to fix both the "Transmission Service Failed To Start" message (even though it DOES start) and/or a constantly spinning progress icon.
You will need to edit these files while the service is stopped, or after the upgrade, but prior to first activation.
