super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
btaroli
Jul 12, 2012Prodigy
ikkieman wrote: ... I seem to have some problems with Transmission 2.42 on Raidiator 4.1.9. The service seems to die every time. ... what can I do? I've changed nothing to the .json file except the max share ratio (set it to 3) and changed true to false on the maximum upload speed.
Well, a few thoughts come to mind:
- 4.1.9 has apparently at least one nasty issue regarding share permissions. I wonder if it's possible that file permissions could be affecting Transmission's ability to access files and it results in crash. See http://www.readynas.com/forum/viewtopic.php?f=17&t=64230. You might want to consider using 4.1.8 instead.
- I don't recall off the top whether Transmission offers a log where debugging info can be captured, but might want to consider doing that to review.
- Though it's often useful to stay on the latest release, you might try going back a version or two and see if you get better behavior.
FWIW, modifying the settings.json shouldn't require ssh access. More recent editions create an addons-config share that you can mount (may require "admin" user) as CIFS or AFP and edit the file that way. Just make sure that Transmission isn't running when you do that. It overwrites the file with current configuration when it shuts down. :)
