super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
MysteryMan1
Jul 17, 2012Aspirant
gibxxi wrote: The add-on won't start automatically from a cold-start on x86 (so this may also be the case for SPARC), so be aware of this when you re-start your NAS, that you *may* need to start transmission manually. Also, if you haven't already done so, set up the start.sh, stop.sh, and blocklist.sh to have the same password / username config you specified in settings.json. All the files are in the same folder if memory serves.
Finally, I wouldn't openly discuss the nature of what your downloading on these forums if I were you. ;)
Sorry to be pedantic, but, I just want to be sure I understand what you are saying.
Until yesterday, I had an older version of Transmission running on my ReadyNAS Duo. I use the power options on the NAS to switch off at night and back on in the morning. Transmission would be there whenever I needed it.
Are you saying that it is likely that the latest Transmission will not restart when the NAS boots up in the morning now and that I will have to manually start it? It does seem that Transmission is not running this morning! I have stopped it and it is in the process of starting again - although it does seem to be taking forever!
This is a real bummer if true!!!!! :(
