super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Hairy1
Aug 20, 2012Aspirant
Thanks for the reply, Im a bit stuck.
Do you have the same issue?
Just to clarify I cant upload by url from within or from outside my firewall, but I can upload by file.
Had a thought, I'll temorarily disable the firewall completely and see if it then works, if it doesn't its nothing to do with the firewall. If it does I could try to isolate port ranges. Fun fun FUN! :wink:
Cheers
John
Cheers
John
