super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Sep 23, 2012Guide
I've been using 2.42 since super-poussin released the version for the ReadyNAS NV+ (v1) Some people have issues where the transmission client turns inactive, others have issues where it just wont start, and others have no issues at all. My issue? The NAS doesn't recognize that the service is infact started after a reboot. I have to use the web interface (Frontview) to turn the service off, and back on to be able to connect to it. It does however seed & download in this state. I've been using Transmission Remote to add, and remove stuff as needed.
MysteryMan wrote: Should I be able to get Transmission working on this set up or should I give up until we get a new version?
If the answer is give up then what are the alternatives for downloading from these new magnet things.....new hardware, new application, use PC-based software, etc?
Since i "never" shut down the NAS my issue isn't that big of an issue, and i sort of expect it to go away with a factory reset, it started showing up when i installed a mod to dim the LED's, for some reason.
B!
