super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
c014
Oct 07, 2012Aspirant
JarnoG wrote: Did you shut down the Transmission add-on before you changed settings.json? If you set rpc-authentication-required to true, it should ask for a un/pw if they are set.
Hello, yes. I have got the password to work now. (kind of, it's seems unreliable, works sometimes others not)
I think the main problem changing the settings.json file was that I am not able to shut down transmission. It says Transmission shutdown successfully. But was probably running anyway. And when I start it it says it failed to start. (which I know realise was because one file have reverted back to original settings).
Now I am mostly confused about the addons-config folder, that I posted about in the post above.
But I guess that if I only make the selection of default access to the share deactivated this will be solved?
