super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Mr_B
Oct 07, 2012Guide
I got this issue as well. I cant connect to Transmission after restarting the NAS, i have to turn of Transmission in frontview, even as it says it's not running, and then restart it to get the failed to start message, and after that it works as "intended". For me the issue showed it's face after installing another addon, and i cant seam to shake it. I guess whiping the system and starting over would work, but i sort of don't have anywhere else to store close to 6 TB worth of data. Even if it's mostly redundant copies, it's a hassle...
c014 wrote: I think the main problem changing the settings.json file was that I am not able to shut down transmission. It says Transmission shutdown successfully. But was probably running anyway. And when I start it it says it failed to start. (which I know realise was because one file have reverted back to original settings).
JarnoG wrote: Did you shut down the Transmission add-on before you changed settings.json? If you set rpc-authentication-required to true, it should ask for a un/pw if they are set.
B!
