super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
whc
Nov 02, 2012Aspirant
JarnoG wrote: Easiest is to do what the message says and check your settings.json. To do so, you will have to log in on your NAS using CIFS or FTP (other protocols might work, but I never tried those) with the admin account. You will then see a share named "addons_config". In the share is a folder named "Transmission" with a folder named "transmission-daemon" in it.
The settings.json file is in that folder.
Open the file with a text editor like Notepad++ or UltraEdit. Don't use Windows Notepad or WordPad since it will save the file in a Windows format which will cause Transmission to crash when loading the settings.
In settings.json, the parameter 'rpc-whitelist-enabled' should be false if you don't want to use a whitelist for the ip addresses that are allowed to access the Transmission interface.
Thanks that fixed the Interface now working, but still not able to start Transmission, how to find the complete path for download folder?
