super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
tylerdola
Dec 14, 2012Aspirant
I really need help with this transmission install. I bought and downloaded tTransmissionBT_2.71-arm-0.5.0 and I tried to install it today on my Duo V2. It seems to break during the install and not complete.
I see files like this in my init.d and defaults folders
When I rename those files to remove the .dpkg-new, It seems to start, but then the web page complains it can't find index.html
It looks like it's a problem with my dpkg:
When I try and -f install I get:
I have more logs to show, but I cannot attach files to this thread. I don't want to take over the whole thread, but I can't seem to solve this problem. I consider myself an experienced user of apt-get, dpkg etc, but by no means an expert. If anyone can help it would be appreciated. I did pay for this :(
Thanks!
-rw-r--r-- 1 root root 451 2011-11-27 11:32 transmission-daemon.dpkg-new
root@dolanas:/etc/default# apt-get install
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libgtk2.0-0 : Depends: libcups2 (>= 1.4.0) but 1.1.14-5woody12.netgear1 is installed
transmission-cli : Depends: transmission-common (= 2.71-0rnx0.5.4) but it is not installed
transmission-daemon : Depends: transmission-common (= 2.71-0rnx0.5.4) but it is not installed
transmission-gtk : Depends: transmission-common (= 2.03-2) but it is not installed
E: Unmet dependencies. Try using -f.
Unpacking replacement libcups2 ...
dpkg: error processing /var/cache/apt/archives/libcups2_1.4.4-7+squeeze1_armel.deb (--unpack):
trying to overwrite '/usr/lib/libcups.so.2', which is also in package libcupsys2 1.1.14-5woody12.netgear1
configured to not write apport reports
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Thanks!
