super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- gabortAspirantHi, I am new to these forums and this platform.
I have a ReadyNAD NVX, an intel based system, and have tried installing Transmision for some time now, but only get "invalid image". It is quite consistent, so I must be doing something wrong.
I have tried all these:
06/19/2010 12:56 PM 11,730,944 PRO-Transmission_2.01b02.bin
06/10/2010 12:11 AM 6,523,392 Transmission_1.93Light.bin
06/19/2010 12:38 PM 8,786,432 Transmission_2.00.bin
06/10/2010 12:00 AM 8,868,352 Transmission_2.00b02.bin
06/19/2010 12:58 PM 14,500,352 Transmission_2.01b02.bin
"invalid image" all the time, also after rebooting. I have a suspicion that perhaps I am using images that are meant for sparc platforms, but there seems to be little in the form of a summary of what images can be found, for which platform.
Can you please direct me to an image that should be installable on my system?
Thanks for your help! - chirpaLuminaryIf you have an NVX, you want a file that starts with PRO-
Can you try another web browser? - gabortAspirantThanks! It worked using IE8. Now why did it NOT work with Firefox 3.5.9?
- veehexxAspirant3.5.9
you do realise the latest is 3.6.3? - veehexxAspirant*ONGOING BUG*
S-P, thanks to charles at tranmission bug trac, there seems to be an issue the way the transmission service stops on the DUO.
i mention this has been happening to me for a while; since around 1.92/1.93. not sure if it's related, but this is possibly around the time you SSH'd into my DUO to investigate a stop/start issue.
charles recommended that i stopped the torrents, waited a few seconds (around 40sec just to be sure!) and then stopped the transmission daemon. restarting the daemon 20seconds later. i then start the paused torrents; torrents resume as normal without any checking.
so, on the face of it, this seems to be an issue with how the start/stop script works on your addon. it appears (to my untrained/uneducated mind), that the daemon is being forcefully & prematurely stopped and therefore not allowing transmission to correctly write the resume data, and so torrents are being rechecked on every daemon start.
i hope that makes sense and you have the time to look into this issue.
i do find it hard im the only one experiencing this issue from both readynas and transmission users, but theres definately something up! :)
if you need SSH access again, then just let me know! - super_poussinVirtuoso
veehexx wrote: *ONGOING BUG*
will produce a new version today or tomorrow - super_poussinVirtuosocan you try :
http://www.readynas.com/contributed/sup ... .01b05.bin
go in /c/addons-config/Transmission and edit the transtop.sh to add your transmission password :)
let me know - veehexxAspirantthanks so much, S-P!
this transtop.sh script does work and stops torrents being rechecked unneedlessly.
however when you re-start the daemon, all torrents are in a paused state, and not their last status prior to when the transtop.sh runs.
this is obviously desired behaviour, but is there anything that can be done? - super_poussinVirtuosoThat' possible but will require some work ( It in my long todo list )
- veehexxAspirantcant say fairer than that!
i'm going to stay on 2.01beta5, since having to access webgui and click 'resume all' is far quicker than waiting for multiple torrents to re-verify every boot :) (i use scheduled power on/off)
