super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- nasaus1Aspirantin your config was that the peer port setting? eg was 54675 "peer port": 54675?
- alexmarasAspirant:) no, i have my router set to forward 54675 (external) to 8181 (internal)
- nasaus1Aspiranthmmm could i get you to send me your a copy of your settings.json and transtop.sh and transtart.sh
because i think one of my settings is wrong because no matter what i do i cant connect remotely
:( - nasaus1AspirantI also wanted my seeds to only seed for like 10mins once done. How do you do this in transmission?
the solution i got was:
option that you talk about?super-poussin wrote: take a look here : http://www.readynas.com/contributed/sup ... meters.htm
(look at ratio and watch )
I changed my ratio to 1
but where iswatch
I only want torrents to seed for eg 10mins
Thanks
Everyone :) - nasaus1Aspirantanyone???
thanks - jaymelisAspirantI've got a bunch of torrents running on my mac mini at the moment. I wanted to put these on the nas so they could seed more and i could clear some space.
I install the Transmission on my nvx and then i start adding the data to the Bittorrent folder. I reupp all the torrents and let him find the data. I do put my downloads at 0 kbps... so i won't accidently download torrents that are allready in.
Transmission only finds 1/3 of the data of the torrents. The other ones he just want to download again. The data is there...
How do i solve this problem? - clowrymAspirantI had posted this its own thread before i saw there was a post regarding transmission.....here may have been a better place!!!
I am trying to get my Transmission Client to store incomplete and Completed torrents on a 500G USB drive connected to my Readynas. I first tried /torrents/ (the name of my USB share) in the preferences pane of the web client, but it still created a file in the incomplete bit torrent folder, and didn't move it once it was completed. then i tried to modify the settings.json file with "incomplete-dir": "/torrents/Incomplete"" for the incomplete torrent settings & "download-dir": "/torrents/", with the second attempt i get "permission denied /torrents//**torrent folder name****"
any suggestions would be greatly appreciated!! - sjwAspirantI've just uploaded over 50GB :shock: to a tracker and none of it has been recorded. :evil:
The stats only update once a day.
Their site mentions stopping the torrent as "This sends the "event=stopped" message to the tracker with your ratio stats for that particular torrent (since you last stopped the torrent)." Does pause do the same thing in Transmission?
Is there any way I can get this data into another client (utorrent?) and try an update from that? Where is the amount I have uploaded stored? - varsasAspirantHi all. I just bought a ReadyNAS Duo and am thinking about installing Transmission since it seems to be the main bittorrent client. How do I install it? Do I just copy the bin? Where should it go and do I then just run the script "transtart.sh"?
Also 2.11 has removed the Watch facility? Is it possible to install this separately? I was hoping to use it with a tool that downloads from rss feeds; regarding this latter tool it looks like Flexget is the best one?
Can I assume that these 2 tools are the best in terms of resource usage?
Thanks. - sdouekGuideDownload add-on from here http://readynas.com/forum/viewtopic.php?f=47&t=24271 then load add-on in frontview>update>local
