super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- vspbAspirantThanks, now works!
- super_poussinVirtuoso
vspb wrote: Thanks, now works!
you're welcome - roostaarAspirantI have just updated to Raidiator beta 4.1.8 T5 to re enable Time Machine support for Lion 10.7.
Transmission no longer works though. I was using v2.11 to comply with a private tracker rules.
I tried re-installing v2.11 but Frontview gives me a 'this addin is not supported by this architecture' error. (error message not accurate as doing from memory).
Any ideas?
Thanks guys - super_poussinVirtuosoroostar : try the last 2.33 version it should work :)
take a look on a post above regarding cookie.txt it will help with private trackers (viewtopic.php?f=36&t=41756&p=314056#p313927) - roostaarAspirant
super-poussin wrote: roostar : try the last 2.33 version it should work :)
Hi super
Does the cookie thing spoof the client version from 2.33 to 2.11?
If so, that would be a considered a bann-able offence by the torrent site! :slap: - super_poussinVirtuoso
roostaar wrote: super-poussin wrote: roostar : try the last 2.33 version it should work :)
Hi super
no it did not spoof only add cookies support if you put your trackers cookies in it
if you need a 2.11 I will try to make a compatible version with 4.1.8 - smcbeeAspirantI just installed 4.1.8 T-5 and I have Transmission 2.33 installed, but it will not start at all. Any ideas?
--Nevermind... I reinstalled 2.33 and it seems to be working. Any idea why my web interface would totally refuse to EVER work, though? - Andreas75kAspirant
Where can I find 2.33? - roostaarAspirant
super-poussin wrote: roostaar wrote: super-poussin wrote: roostar : try the last 2.33 version it should work :)
Hi super
If you could make 2.11 compatible, I would be happy to donate another 5 Euro! :)
If it's a boat load of work though, don't worry. I'm sure the beta will be updated soon enough and 2.11 will become compatible again. - roostaarAspirant
Andreas75k wrote: super-poussin wrote: roostar : try the last 2.33 version it should work :)
viewtopic.php?f=47&t=24271
