super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- sjwAspirantSame here Andreas. Except now, when I try to update the blocklist (Transmission Remote 3.24) I get the error "gotnewblocklist: http error 404: Not Found" :(
How high do your download speeds reach on your Duo? - Andreas75kAspirant
sjw wrote: Same here Andreas. Except now, when I try to update the blocklist (Transmission Remote 3.24) I get the error "gotnewblocklist: http error 404: Not Found" :(
No problems with the blocklist that I know of. Just tested download speed with the latest episode of The big bang theory and speed was between 1,2 and 1,5 Mb/s. Seems ok to me as I'm on ADSL. Sure, I should have 24 Mbit (3 Mb/s), but about 12 Mbit seems to be what I can get out of this old phone line.
What do you get? - dafunk85AspirantI have a problem after installing transmission 2.33.2 in my readynas pro 6
the problem is, after installing transmission, it replace all my data files in media folder especially in CIFS sharing protocols, it replace with transmission folder but the files is not deleted just hid by transmission folder.
the question is, can i make my data files back appear again, coz i really need those files, especially when share with CIFS share protocols, the other protocol is not problem
please , really need the solusion :( - I bought a new Readynas Ultra Plus 4 yesterday and I'm running 4.2.19. I haven't installed any software except Transmission 2.34 beta 4 and I'm having a lot of problems. If i download more than 3 torrents the whole GUI freezes up, if I try to update in frontview to the latest Transmission build it failes and I can't access Transmission anymore, I can't reinstall it over the previous version either, then i get a error message. Right now I have run a factory default on my readynas, does anyone recommend a good stable version of transmission?
- sjwAspirant
I'm on a 30Mb connection and if I download using utorrent to the PC I get 3.5 - 3.6MB/s no problem. i.e. max out the connection. Through Transmission on the Duo I occasionally may reach 1.5MB/s. (note the MB and Mb).Andreas75k wrote: ...Just tested download speed with the latest episode of The big bang theory and speed was between 1,2 and 1,5 Mb/s. Seems ok to me as I'm on ADSL. Sure, I should have 24 Mbit (3 Mb/s), but about 12 Mbit seems to be what I can get out of this old phone line.
What do you get?
I would avoid 2.34 - many people seem to be having problems with it. Sadly no replies back yet. :(sveinemonster wrote: I bought a new Readynas Ultra Plus 4 yesterday and I'm running 4.2.19. I haven't installed any software except Transmission 2.34 beta 4 and I'm having a lot of problems. If i download more than 3 torrents the whole GUI freezes up, if I try to update in frontview to the latest Transmission build it failes and I can't access Transmission anymore, I can't reinstall it over the previous version either, then i get a error message. Right now I have run a factory default on my readynas, does anyone recommend a good stable version of transmission? - mustang2Aspirant
dafunk85 wrote: I have a problem after installing transmission 2.33.2 in my readynas pro 6
I have the same problem with ReadyNAS Ultra 2. I just installed transmission for the first time and was prompted to update to version 2.40.03 which took several attempts to update. After that my saved files were no longer visible on the ReadyNAS or through Windows. The funny thing is that the ReadyNAS Frontview disk usage indicated that the files were taking up space and my TV was still able to stream these files via DLNA service. I had to reset the unit to factory default and start from scratch. Seams like a bug somewhere. - mateuszwdowiakAspirant
Andreas75k wrote: mateuszwdowiak wrote: Hello,
Recently I've been using Transmission 2.31, but the out of memory exception occured, so i got back to Transmision 2.11...
Downloading torrents seems to be ok, but i have a problem with uploading- there are always only 0 or 1 peer available, but most of the time there is no peers available.
The port is open on my router, so I don't know what else can i do...
Maybe i can change anything in the settings or something?
Do you have any ideas?
You can try the new beta from here:
http://www.readynas.com/forum/viewtopic.php?t=24271#p133300
Unfortunatelly, when using a new beta version, the problem still occurs. I have no peers available for my torrents. Please, any ideas what can i do ? - lappen71AspirantThe only version that works for me is 2.1x
Only trouble is if i turn of My Nas Transmission verifies all my torrent that's not finished. - mateuszwdowiakAspirantand another issue is that when i restart ReadyNas transmission doesn't start
- Now I have tried my way through all the updates from 2.11 to 2.34 beta 4, if I use 2.11 i download most torrents with a speed well above 6 MB/s but transmission randomly stops and i can't download torrents from eztv.it... Now I'm back on 2.34 beta 4, the only version that doesn't stop on me, but I only get a maximum download speed of about 1 MB/s, torrents from eztv.it will seed, but torrents from sites I'm registered to won't seed. The last couple of times I tried to upgrade to 2.40.03 via frontview I got a error message and the transmission add-on disappeared from the add-on menu in frontview, I wasn't able to reinstall it either without doing a factory default of the NAS. So does anyone have any idea how I can get transmission seeding, and getting faster download speeds? How to successfully upgrade to 2.40.03? The speed is not limited in the preference menu.
