super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- super_poussinVirtuoso
verb14 wrote: Also - how do I get Transmission to start automatically when the NAS starts up - as of now, I have to enable Transmission each time from the Apps page
Edit: Using an RN102 with 6.0.8
(I have changed the default login and password)
cheers...
Which version did you see in frontview ? - verb14AspirantIt's 2.80 - also tried updating to the 3.00.3 version (from 3.00.2) from your dropbox. Rebooted/disabled/enabled/rebooted. Still not starting when the NAS starts (I'v set it to be off during the day)
On a RN 10200 running 6.0.8
cheers... - super_poussinVirtuosoCan you try this :
Remove transmission
Remove the transmission share
Install it again - verb14AspirantNope, uninstalled, removed share; re-installed...
No luck - I have to log in to the web control panel and flick the Transmission switch to 'on' in the Apps tab. - Mr_BGuideAny other addons installed?
B! - kraftyskillzAspirant
verb14 wrote: --download-dir /data/Transmission/Donwloads"
There's a mismatch / spelling error in the Downloads dir entry in this line from start.sh . I really have no clue whether some of the issues stem from this but the dev might be able to help.
Also, is it possible to choose a separate download dir for each torrent? Shifting stuff to a different share is damnably annoying as it takes ages - even through the web interface. ( RN 6.0.8 )
Thanks for pointing that out. Dunno if i should give up on transmission for now. Never got it working and already had too much problems with the Nas itself. :? - verb14Aspirant
Mr_B wrote: Any other addons installed?
B!
Just Plex.
... Could someone tell me where the Transmission logs are saved ( 6.0.8 / Arm ) ? - kraftyskillzAspirantSo i've tried giving transmission another go. So far its crashed my storage during the installation and now when i tried switching it on, it's become unresponsive and keeps asking for my dashboard credentials.
I normally like a bit of a challenge but this i'm going to gladly give up on. - flamesong1AspirantI have been having a Transmission nightmare since my ReadyNAS Duo upgraded itself to RAIDiator 4.1.12 this morning - I had disabled automatic upgrades so I'm not really sure how this happened.
Anyway, since the upgrade, Transmission has been crashing non-stop and attempting to restart it via Frontview has failed. I have reinstalled it several times but eventually, I reverted to RAIDiator 4.1.10 and it still failed to launch until I reinstalled it yet again.
I'm not feeling very confident that it will keep going for very long. - flamesong1AspirantSure enough, it crashed again.
By the way, I'm using Transmission v2.42.
