super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- delhuxAspirantCan someone tell me where I can edit the text displayed by the whitelist 403 page?
- cip74coolAspirantI am experiencing the same problem of being unable to stop (GUI or command line) or remove (GUI) Transmission.
Note: I installed Transmission 2.01 on top of a disabled (stopped) Transmission 2.00 installation.
netgearNAS:/c/addons-config/Transmission# ./transtop.sh
head: -1: invalid number of lines
head: -1: invalid number of lines - cip74coolAspirantI've done some debugging and the error is in the line:
IDDLE="$($REMOTE $TRANSOPT -l | tail -n +2 | head -n -1 | grep Idle |awk '{ print $1; }' | awk -F "*" '{ print $1; }')"
and more exactly the "head -n -1" command. Everything until then works (returns the list of torrents still seeding). - cip74coolAspirant...but all my torrents show as Status: Stopped anyway. So how exactly do we troubleshoot and get rid of the GUI error? populateDivFromUrl ...
- super_poussinVirtuosoGive me Time to investigate
- super_poussinVirtuosodownload 2.01 again it should be solved
cip74cool wrote: I've done some debugging and the error is in the line:
can you do this for me
1) copy transtop.sh to test.sh
2) edit it
3) remove the loop at the end :
for ID in $LIST; do
$REMOTE $TRANSOPT --torrent $ID --stop > /dev/null
done
4) add this code
5) launch test.sh
6) post results or send it by PM - cip74coolAspirantI can confirm re-downloading 2.01 and re-installing it solved the GUI problem. I was able to access the Installed Add-ons GUI screen, stop and then re-start Transmission. Thanks a lot for the quick response!
- danielvegas1AspirantI am still banned from a tracker requiring 2.0.1. The version 2.00 is not allowed. I think it might be a problem with the Transmission-release itself, because under "Preferences" it says 2.00+.
Is this a known issue?
edit: So I had two "transmission-da"-processes in "top" and killed them both, then restarted Transmission via Frontview. Now the version-issue seems to be done with, but the Inspector does not contain the "User"-section anymore.
Weird?! - super_poussinVirtuoso
danielvegas wrote: I am still banned from a tracker requiring 2.0.1, which not allows 2.00. I think it might be an issue with the Transmission-release itself, because under "Preferences" it says 2.00+.
CAN you download the add-on again from this site and install it again then let me know
