gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
chirpa
Apr 30, 2009Luminary
AndersE wrote: Hi! I have put the news directory under /usr/local/bin and when I run chmod 775 -X newcs, start I get the answer NasServer:/usr/local/bin/newcs# chmod 775 -X newcs, start
chmod: getting attributes of `775': No such file or directory
chmod: getting attributes of `newcs,': No such file or direct
Also when i run insmod fdti_sio.ko i get thisNasServer:/usr/local/bin/newcs# insmod fdti_sio.ko
insmod: can't read 'fdti_sio.ko': No such file or directory
Try just single chmod commands like 'chmod 755 newcs' and 'chmod 755 start'.
Did you download the two listed modules do that same directory? You can't insmod a module that doesn't exist. Try using wget to download those two files first.
