gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
rosens
Nov 26, 2009Aspirant
WhoCares? wrote:
rosens wrote: But is it possible to make a script so NewCS startup automatically at bootup?
As already stated by super-poussin, you can always make an addon of your project. If you don't want to go through all the steps neccessary, the easy solution would be to create a startup script like for example "00_newcs.sh" and put it in the /var/spool/frontview/boot/ directory. Make sure the script is owned by admin (by doing a "chown admin:admin 00_newcs.sh"). This script will get executed on every startup.
Likewise, if you need to shut down some drivers/daemons when powering down the ReadyNAS, you can put another script in /var/spool/frontview/shutdown. The same rules as above apply.
-Stefan
Thanks Stefan,
So if I make a script with the lines:
insmod /usr/local/bin/newcs/usbserial.ko
insmod /usr/local/bin/newcs/ftdi_sio.ko
/usr/local/bin/newcs/./newcs -c newcs.xml
and do as you say - it should do the trick?
regards rosens
