gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
rosens
Jan 01, 2010Aspirant
Hi all - and Happy Newyear! :D
I have NewCS 1.65 running fine on my ReadyNAS DUO with a Smargo Smartreader+ USB. It reads the card as it should. All types of client types gets good ECM's from my server.
But I have discovered that the card does'nt get any EMM's. :(
I'm suspecting that it could be a driver issue because i'm successfully getting EMM's with NewCS, Smargo on a Qnap NAS with exactly the same configuration.
Anyone with same experience?
I'm using these drivers:
http://www.readynas.com/download/modules/ftdi_sio.ko
http://www.readynas.com/download/modules/usbserial.ko
hope someone has a solution.
regards rosens
regards rosens
