gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
AltaControl
Mar 14, 2010Aspirant
bloemkool11 wrote: Hi,
My first post here...
I'd like to run newCS on my NV+, and trying the package offered here..
It should work because the processor is the same ( sparc afaik )
When I insmod the ftdi_sio module, I get :# insmod ftdi_sio.ko
insmod: error inserting 'ftdi_sio.ko': -1 Invalid module format
Any Ideas or updates from the guru's ?
thanks a lot ...
Hi having the same problem...any suggestions plz? Answers are hard to find :(
thx
