gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
rutgercjonaker
May 04, 2010Aspirant
Hi!
I just got me a readynas duo on which I planned to run newcs.
I had some trouble first with my disk so I upgraded to latest firmware.
Firmware: RAIDiator 4.1.7-T29 [1.00a043]
Now, when I have downloaded the newcs SW and used the correct
.ko-files which loads OK, newcs segmentation faults when I start it.
Should I go back to firmware 4.1.6? Is it a different linux version?
Also, I do not have a library "/usr/local/lib" which is setup in the start script.
/Lars Johan
readynas1:/usr/local/bin# lsmod
Module Size Used by
ftdi_sio 33480 0
usbserial 29608 1 ftdi_sio
uhci_hcd 27192 0
ehci_hcd 36336 0
padre_nand_flash 4164 0
padre_i2c_hwmon 14000 0
padre_p0_led_button 17496 0
padre_des 5552 0
padre_gmac 99720 0
padre_io 546224 0
padre_i2c_rtc 8948 0
padre_i2c 15960 4 padre_i2c_hwmon,padre_p0_led_button,padre_gmac,padre_i2c_rtc
readynas1:/usr/local/bin# ./newcs -c ./newcs.xml
Segmentation fault
/Lars Johan
