gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
Stroker
Apr 07, 2011Aspirant
Since I'm happy today and got everything to work I will share what I learn. Maybe its rubbish for some or even most of you but if I had had the answers to all my silly questions it would have spared me a lot of hours and a almost collapsed marriage.
The solutions was really simple and that I would have known if I was knowing what I was doing.. You see what I mean.. First I learn.
* to execute a file from readynas filesystem I had to write ./
If that didnt work it was almost every time because that file wasn't any good for my readynas....... I tried also to chmod -x it but it never did work.
* to execute a module (usbserial.ko and the other) I first ha to go to the library were its was copied from my winspc program. If im standing in the root (which I came to by using the "ssh" change in my readynas panel that I downloaded from the forumsite to make it possible to get into the filesystem.. and then restart the readynas to get it to work.... and then install the winspc.. I had to write ( used the putty window) cd/usr/local/bin/newcs/ (I made the library newcs myself) fx and then I wrote insmod (which probably means "insert program in the toolbox" so to speak) - and the filename. Sometimes I had to write chmod 775 and the filename first to make the file read and writeable.
To be sure if it was there working I wrote lsmod and then i could see if the files had started to work.
Everything sofar I learn from this side and some other but I write it anyway since I'm so stupid I didn't understand by the writing.
The problem I had almost all the time from start (know now it was almost right from start) that have been all the time was two things.
First- if i use a phoenix reader from adteknik in sweden and I had to write ttyUSB0 in newcs.xml .. and second it works 358mhz and not 368. So simple was that that I had worked with and banged my head in to periods in three months.
Hope you guys dont mind a stupid one like me tries to explain for other stupid ones i guess is out there. If anybody dont care and doesn't give a shit I at least explained it for myself :)
Greetings from sweden.
