gabbano
Jan 28, 2009Aspirant
NewCS on ReadyNAS DUO!
Hi all, I dont know if this is the right place to post but... I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS do...
zukon
Dec 13, 2013Aspirant
Hello!!
Based on information in this forum I make oscam compilation for SPARC architecture :D my last compilation:
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn9092-sparc-linux
and some older:
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7157-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7173-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7184-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7750-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8377-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8699-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8821-sparc-linux
https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8988-sparc-linux
Runing script (put in /var/spool/frontview/boot)
02_rs232_usb_oscam
Somtime I put SPARC compilation with other on pkteam.pl (sh4/arm/mips).
Regards
zukon/PKT
Unix starttime: 1386884940
Starttime: 12.12.2013 22:49:00
Version: oscam-1.20-unstable_svn-r9092
ConfigDir: /usr/local/bin/
Web interface support: yes
Touch interface support: yes
SSL support: no
DVB API support: yes
DVB API with AZBOX support: no
DVB API with MCA support: no
DVB API with COOLAPI support: no
DVB API with STAPI support: no
Anti-cascading support: yes
Irdeto guessing: yes
Debug mode: yes
Monitor: yes
Loadbalancing support: yes
CW Cycle Check support: yes
LCD support: no
LED support: no
IPv6 support: no
Cache exchange support: yes
camd 3.3x: no
camd 3.5 UDP: no
camd 3.5 TCP: no
newcamd: yes
CCcam: yes
CCcam share: yes
Pandora: no
ghttp: yes
gbox: no
radegast: no
serial: yes
constant CW: yes
Reader support: yes
Nagra: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_phoenix: yes
cardreader_internal_azbox: no
cardreader_internal_coolapi: no
cardreader_internal_sci: yes
cardreader_sc8in1: no
cardreader_mp35: no
cardreader_smargo: no
cardreader_pcsc: no
cardreader_smartreader: no
cardreader_db2com: no
cardreader_stapi: no
cardreader_stinger: yes
and some older:
02_rs232_usb_oscam
#!/bin/sh
#/var/spool/frontview/boot albo zmienin na start.sh i uruchamiaj z reki
/sbin/insmod /usr/local/bin/usbserial.ko
/sbin/insmod /usr/local/bin/pl2303.ko
#/sbin/insmod /usr/local/bin/ftdi_sio.ko
sleep 3
#/usr/local/bin/newcs -C /usr/local/bin/newcs_phoenix.xml
/usr/local/bin/oscam -b -c /usr/local/bin/
Regards
zukon/PKT
