soremaniac
Apr 19, 2020Aspirant
No Web Interface - Frontview gone ;-( on my ReadyNAS Pro
Okay I shut have read until the end*, but I dit not. I (tryed) to install Pi-Hole on my ReadyNAS PRO with 6.9.6 (*= Pi-Hole Web Interface also uses http://ip-nas.local/admin -> yes realy BAD!) So...
soremaniac
okay I will try it, but it is still a mistory why Upload to my NAS goes with no problem (110MB/s), but the Downloads aren't working at all...(I think the installation of Pi-Hole killed more than the GUI). But how I cut find out what is the problem there?)
Apr 19, 2020Guru - Experienced User
soremaniac wrote:
okay I will try it, but it is still a mystery why Upload to my NAS goes with no problem (110MB/s), but the Downloads aren't working at all...(I think the installation of Pi-Hole killed more than the GUI). But how I cut find out what is the problem there?)
Certainly odd, but It seems unlikely that it killed Samba.
You can still do a backup by attaching USB drives to the NAS and mounting them manually. Or create a share on the PC, and create a mount point for that on the NAS.
- soremaniacApr 23, 2020Aspirant
can you tell me wher in the terminal I find the USB Storage Volume? (the path?)
PS: I can say $ /sys/bus/usb/ is not the real deal
and /dev/bus/usb is also nothing .-(
- StephenBApr 23, 2020Guru - Experienced User
The NAS software mounts USB drives to /media. For instance, /media/USB_HDD_1
