Mitch72
Sep 20, 2010Aspirant
NZBGet WebGUI Password?
Has anyone been able to get NZBGet to require a username and password to access the web client? I've looked at the settings.php file: // username for web-interface. Leave it blank to disable...
dendave
Jul 28, 2011Aspirant
Think I solved it myself. Not really familiar with PHP but a search on the internet learned me that REQUEST is not really recommended to use.
You should use POST instead.
So changed login.php from:
To:
That did the trick for me!
$auth_valid = false;
if (isset($_REQUEST['username']) || isset($_REQUEST['password'])) {
$auth_username = $_REQUEST['username'];
$auth_password = $_REQUEST['password'];
} else {
if (isset($_SESSION['auth_username']))
$auth_username = $_SESSION['auth_username'];
if (isset($_SESSION['auth_password']))
$auth_password = $_SESSION['auth_password'];
To:
if (isset($_POST['username']) || isset($_POST['password'])) {
} else {
