Bob245
Apr 17, 2019Guide
OS6.x on ReadyNAS Pro 4 (RNDP4000) the last firmware supported and link to download it
Hi everyone, I am testing a RNDP4000 ver 4.2.31 with 4 WD 3TB disks each and it mount 1024 of DDR2 ram.
I would like to switch from version 4.2.31 to version OS6.x.x.
I have read various tre...
- Apr 18, 2019
Bob245 wrote:
With the firmware 4.x I could use up to 3Tb disks (which are the ones that are mounted now).
With OS6.x can I mount larger disks? Up to what size can I use? Thank you.
There's no known limit, so you could use 14 TB (which is the largest disk currently available).
FWIW, 4-bay 4.2 systems using XRAID could go up to 5 TB drives (15 TB volume size).
Bob245
Apr 17, 2019Guide
Ok, everything is clear to me, thanks!!
I have already downloaded the prep firmware and the OS 6.x firmware that you have indicated to me.
I am activating to upgrade the memory to 2Mb.
Only one last clarification: if the ugrade to OS6.x goes wrong, it will be possible with adequate procedure, to return to version 4.x?
Today I will open a new tread because I need some clarifications on the use of the encryption feature that OS6.x should have.
Eventually we feel on the new tread.
Thanks again and congratulations for your competence and professionalism and for patience in following me in this upgrade. Bob
Apr 18, 2019Guru - Experienced User
If the upgrade works correctly, you can revert to 4.2 firmware.
If the upgrade goes wrong, then it depends on what fails I guess.
- Bob245Apr 18, 2019Guide
Bob
- StephenBApr 18, 2019Guru - Experienced User
