Bob245
Apr 17, 2019Guide
OS6.x on ReadyNAS Pro 4 (RNDP4000) the last firmware supported and link to download it
Hi everyone, I am testing a RNDP4000 ver 4.2.31 with 4 WD 3TB disks each and it mount 1024 of DDR2 ram.
I would like to switch from version 4.2.31 to version OS6.x.x.
I have read various tre...
- Apr 18, 2019
Bob245 wrote:
With the firmware 4.x I could use up to 3Tb disks (which are the ones that are mounted now).
With OS6.x can I mount larger disks? Up to what size can I use? Thank you.
There's no known limit, so you could use 14 TB (which is the largest disk currently available).
FWIW, 4-bay 4.2 systems using XRAID could go up to 5 TB drives (15 TB volume size).
Bob245
Apr 18, 2019Guide
Bob
Apr 18, 2019Guru - Experienced User
