malanciault
Jun 26, 2023Aspirant
Outbound SSH port 22 is blocked
Hi, We have a Netgear Nighthawk RAX48 and port 22 is blocked outbound. So if we try to SSH in a server outside the network, we get a timeout. From outside our network, it works perfectly. How...
schumaku
Jun 26, 2023Guru - Experienced User
RAX48 or a XR700? Either way, this "ReadyNAS Storage Apps - Old & Legacy Apps" is certainly the wrong community.
malanciault
schumaku a écrit :RAX48 or a XR700? Either way, this "ReadyNAS Storage Apps - Old & Legacy Apps
RAX48
And I did not relevant community, sorry. Let me try and edit the original post.
- malanciaultJun 26, 2023Aspirant
Ah, I see what you mean about the community. Thanks I'll post it at the correct place.
Posted in the right forum (I hope ;))
- schumakuJun 26, 2023Guru - Experienced User
Start from Nighthawk With WiFi 6 (AX) And WiFi 6E (AXE) Routers Discuss Nighthawk (RAX and RAXE Series) router products. for discussing the Nighthawk (RAX and RAXE Series) router products.
Appears the RAX48 is not explicitly listed yet (brand new model), so you might want to start with this RAX48 Firmware Version 1.0.15.128 - Hot Fix
- malanciaultJul 26, 2023Aspirant
Hi,
I have installed the hot fix RAX48 Firmware Version 1.0.15.128 - Hot Fix
It did not resolve the problem. I still cannot access port 22 outbound.
I tried to contact support but did not get any reply.
Anyone can help ? Thanks!
