mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
mdgm-ntgr
Sep 26, 2012NETGEAR Employee Retired
OwnCloud requires PHP >= 5.3 (http://owncloud.org/support/requirements/) so no super-poussin's PHP add-on won't work as it's too old.
To update to the newer PHP I believe you simply install the ReadyNASXtras PHP add-on twice (without removing it, install it over the top of itself).
